Berlinetta common problems?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Brlinetta's never have electrical problems ?!?!?!?!
1a) Radio Cassette ( door will not open)
1b) Radio Cassette ( cassette will not play )
2a) Blinker(s) (switch, unsually the left turn )
2b) Blinker(s) (Light Module had a seizure )
3a) Exterior Lighting ( headlights stay on, light module toasted )
3b) Exterior Lighting ( NO headlights - light module toasted )
3c) Interior Lighting ( Courtesy Lights stay on - light module toasted )
4a) Speedometer Cluster ( burnt out circuit boards )
4b) Speedometer Cluster ( Works fine during the day but goes dark when headlights are turned on, light module toasted )
5a) Wiper will not turn off ( Wiper OFF button broke
5b) Wiper will not turn off ( Wiper Motor cover fried )
6) No Air Cond. ( pod not sending battery voltage to AC system )
7) Heater blower speed ( blower relay spazzed out )
8) Air Flow from heater blower ( Vacuum Soleniod only allows air flow from the defroster vents )
There are more, but you get the idea...... The order in which the *major* berlinetta electrical parts seem to fail the most often is :
Radio
Blinker pod
Light Module
Speedo Cluster
Wiper pod
Hope that helps yo in some way !!
Radio
Blinker pod
Light Module
Speedo Cluster
Wiper pod
Glowsock
Sep 6, 2015 06:40 AM
