custom wiring
Old May 29, 2005 | 12:56 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
custom wiring
Ok, first let me explain. I did a v6-v8 swap, MPFI to Carb. I pulled every last bit of wiring out of the car. Now i'm redoing all of the wiring and I made a diagram to help me. Can you tell me if I have my head in my ****?
R = Relay
S = Switch
I was looking to use 30AMP relays for every relay represented in this diagram. I planned on putting the fuel pump, electric choke and the distributor on the same relay.
I didnt use a relay on the starter, i figured since it will only receive +12v for a short time period, it wouldnt need one.
I have no clue what to do with the alternator wiring. There are 3 wires coming from the pigtail. Where do they go?
Hopefully I have this all correct. If not, yell at me
I did this in Autocad, if you want a copy of the DWG, let me know.
Old May 31, 2005 | 01:17 AM
Car: 88 Camaro
Engine: 310 LG4
does anyone know? I'm sure that there is at least one person on this board that knows basic electronics.
Old May 31, 2005 | 03:07 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can u do that in a normal type schematic with symbols? and what are those S's for in those little boxes???
Old May 31, 2005 | 05:46 PM
Car: 88 Camaro
Engine: 310 LG4
As state din original post:
R = Relay
S = Switch
I think my diagram is pretty simplistic.
Old May 31, 2005 | 07:03 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
That makes no sense. I'm not even going to try and decipher it becuase the first thing I noticed is the relays are even labeled. It just has a jumble of wires going to it. Use correct symbols for relays and switches and maybe it'd make sense, although I'm not totally sure why we are trouble shooting it. Also, make sure your starter switch can handle the current the starter draws. It may be brief but its alot of current.
Old May 31, 2005 | 11:39 PM
Car: 88 Camaro
Engine: 310 LG4
i just wanted to know if the basic concept is correct, i'm not looking to get specific, i can handle the details of wiring a relay, i just wanted recommendations on relay amperage for fan, etc and to know if it would be a good idea or not to have the distributor, choke and fuel pump on the same relay. Thats it. I'm not here to ask why this doesnt work, i just want to know if the basic conepts are there, which i believe they are, does it really matter if i add 85, 87, 87a, etc to the relay? I know where +12v and the switch goes, so what does it matter? I appreciate the help you ghuys offer, but dont be so quick to jump my case, this isnt a complex situation.
Old Jun 1, 2005 | 06:37 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i would put the fuel pump on a separate relay, incase something goes wrong u wont have 3 components not working at the same time....
Old Jun 1, 2005 | 12:28 PM
Car: 88 Camaro
Engine: 310 LG4
ok. You think a 30amp relay will be ok for the pump?
Old Jun 1, 2005 | 12:57 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
i think 30 maybe a bit high...... ill check the specs on my 85 just for a fyi and let u know....
Jeremys87
Jul 14, 2022 09:08 PM
midge54
Sep 2, 2020 07:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
djmarch
Aug 19, 2015 12:07 PM
