no power
Old Jun 4, 2005 | 11:36 PM
UDAMON's Avatar
Car: Mazda Protege5
no power
ok well. my starter went bad. so i changed it, and after i installed the new one and hooked the battery back up nothing nowhere works. no power to anything. tested all fusible links, conductivity to everywhere, battey is fine everything seems ok its just that nothing works....
any tips before i have to tow it in?
was wondering if theres a certain spot where all power goes into the car that could be bad besides fusible links...
Old Jun 5, 2005 | 10:48 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Nope, go back and check your connections at the starter and back sure that you have the wires in the right position. The purple wire with the small terminal lug goes on the small post marked "S" and all the other wires with the large terminal lugs go on the large top post with the battery cable. If you still have nothing, check the battery cable. You didn't by any chance remove the ground wire from the engine did you?
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
