firebird gauge switching
Old Jun 10, 2005 | 12:53 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
i have a v6 '88 bird and have the 120 speedo, and an 0 to 80 oil pressure gauge. i have a 140 speedo laying around that i want to put in my car, but i know the oil pressure only goes up to 60 and the tach redlines at 5500 instead of 6000. can i just take the 140 speedo out of the cluster and put it in my 120 cluster and have everything work right?
Old Jun 11, 2005 | 03:09 PM
eagle_eyes's Avatar
Engine: '93 LT1
anybody know????
Old Jun 11, 2005 | 03:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Should be able to, as long as the 140 speedo is eletronic like your 120 and not mechanical.
Old Jun 13, 2005 | 12:39 PM
eagle_eyes's Avatar
Engine: '93 LT1
they are both from '88 firebirds. do i need to switch the curcuit board on the inside that the speedo is hooked up to as well?
Old Jun 13, 2005 | 07:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, should just be able to swap the speedo head itself.
Old Jun 18, 2005 | 02:38 PM
eagle_eyes's Avatar
Engine: '93 LT1
when you say head, your not just talking about the face, right? cause the 120 mark and the 140 mark are at the same spot
Old Jun 18, 2005 | 03:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The face and the rest of the guts of it.
Old Jun 18, 2005 | 03:39 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Unscrew the 5 screws in the back where the speedo is on the one cluster, then the 5 from the cluster in the car, and swap out the entire gauge.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 02:00 PM
