parking lights/ front turn signals
Old Jun 23, 2005 | 10:06 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i want some parking lights that are very bright that come on the newer cars like corvettes and cadillacs. You know the ones that stay real bright and then when you put on the turn signal the light will go out and come back on, as oposed to the ones we have on our third gens that are dim and then when you hit the turn signal they get brighter then go back to dim. does anyone know where i can get some of these lights?
i know this might be a stupid post but i thought id try and see if any one on here knew about where to get them....
Old Jun 25, 2005 | 12:29 PM
Vader's Avatar
You already have them. Some of the newer DRLs use the higher intensity lamp filaments constantly as running lamps, and switch them when turn signals are applied. You'll have a lot of wiring changes to perform to pull that one off, but it can be done.
1992rs/ss
Jan 31, 2025 05:10 PM
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
