ARC fuse
Old Jul 19, 2005 | 09:59 PM
chrisozanne's Avatar
ARC fuse
Anyone know what the ARC fuse is for in the fuse panel of a 91 z-28? mine keeps blown car want run at times and id like to track it down plse hlp my ole 200600 mile car .
Old Aug 27, 2005 | 07:04 PM
Kandied91z's Avatar
ever figure this out? mine isn't blowing but it's pulling a constant draw on the battery when the key is off...
Old Aug 29, 2005 | 04:11 PM
The ARC fuse goes to the radio ( the wire that keeps your radio memory). GL with it hope you firgure it out . Im sad to say im no longer a Camaro owner bout me a 98 grand prix gtp ( supercharged ) :P
Old Aug 29, 2005 | 05:24 PM
Kandied91z's Avatar
does anyone have any idea how much this ARC fuse circuit should drain. i'm assuming since it is a constant that technically it should light up a test light in theory it's always going if it's constant right?
as far as the grand prix that's nice, i have one myself with some extras. good luck with it too as i have had more recals and things go wrong with that car then any of my other cars.
but it's still fun to drive.
Old Aug 30, 2005 | 06:41 PM
Marc 85Z28's Avatar
You should never have more than 500 milliamp current draw on any circuit. On a standard test light (12v, 12ohm) 1 amp should light it fully. If you can see a dark orange filament thats dimly lit you should be OK.
On a newer car with several electronic control modules 400-500 milliamp would be acceptable (some Ford products normally draw a little over 500 milliamp). However vehicles like ours with little to no electronic memory should be under 250 milliamps. My car draws only around 100 FYI.
Old Aug 30, 2005 | 11:49 PM
Kandied91z's Avatar
yeah it lights fully and the light goes out when i remove the fuse. what should i do then? i've never tested this before so i don't know if i've always had this problem or not.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
