Lamp driver
Old Jul 19, 2005 | 10:35 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Lamp driver
Hi all,
Do all cars use a lamp driver? On my '82 it seems connected between the ALDL connector and the SES light. Is it used on later year TPI cars? If someone has a wiring diagram of the relevant section of the manual they could post I'd appreciate it.
Old Jul 20, 2005 | 12:09 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is called a light driver module and it is found in carburated vehicles up through 1987. I have found no sign of it being in any TPI vehicle so far.
Old Jul 20, 2005 | 03:59 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
The lamp driver was removed from my 82 bird when I installed the 350TPI motor. The TPI ECM drives the SES lamp directly.
Old Jul 20, 2005 | 04:06 PM
Car: 1989 Trans Am
That's awesome, thanks for that info guys. That's one less problem for me to worry about.
How come GM removed the SES line on the ALDL connector? According to a wiring diagram I saw for '89, it's not there anymore.
Old Jul 20, 2005 | 08:19 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not sure what you mean by the SES line on the ALDL being removed. It is still in the same spot it has always been. The SES light runs to the ECM, not the ALDL.
Old Jul 20, 2005 | 09:51 PM
Car: 1989 Trans Am
On my '82 there is a connection on pin D on the ALDL, but I noticed on a '89 wiring diagram there is no connection. This is what I meant when I asked if it had been removed from the ALDL in later year cars. Was the diagram I reading incorrect?
Old Jul 20, 2005 | 10:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, you weren't reading your schematic entirely wrong. Pin "D" of the ALDL for your car was for the light driver module. As mentioned in an earlier post, the light driver module was only used on cars with carburated engines from 1982 to 1987. Since the light driver module was not used on non-carburated engines such as the TPI & TBI, there was no further need for a terminal for it on the ALDL. I hope this answers your question.
Old Jul 20, 2005 | 11:03 PM
Car: 1989 Trans Am
Yep! Thanks a bunch!
Veaceonee
Sep 29, 2016 08:15 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
jerflash
Exterior Parts for Sale
Sep 22, 2015 09:58 AM
abrilnelson89
Sep 17, 2015 10:41 AM
