Yellow buffer box on ECM?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I took down my ECM and it's an aftermarket replacement and it has a yellow buffer box right by the wiring harness. I'm wondering if its stock, and if I'll need it for my SD swap I'm doing today. Thanks.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yellow box (speed buffer)
If you are switching to SD, no....you won't need it.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: Yellow box (speed buffer)
Car: 86 T/A
Engine: HSR 355
I'm having the prom burned so I use my stock VSS so basically I'm just using the pin changes listed on the tech article floating around this site.
Originally posted by firebirdjosh
I didn't see any info on removing it from the website about the conversion.
I didn't see you were working on an '86.
If you are using a '7730 the brown wire from that buffer will go to pin #C6 on the C & D connector (it probably goes to A10 now).
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I'm not sure which tech article that you are using, the one that I have seen on this board is for switching 1990 - 1992 camaros to speed density. I haven't seen anything for firebirds.
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
The VSS buffer is used not only for the ECM but also for the CC and speedo. The signal from the gearbox is divided in different ways in the yellow box and then used for different sources in the car
Re: Yellow buffer box on ECM?
Hey Guys I'm hooking up a electric speedometer in my 85 Firebird (with a 88 TBI swap) and have the yellow buffer box.....I have all the wires covered except the two browns....I know one goes back to the ECM, where does the other one route to? Cruise control maybe?
Does it matter which brown goes to which....I figured the output was the same.
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Wow, talk about resurrecting an old thread.
Look at this diagram, it will tell you which wire exactly goes where. Don't mix them up. http://www.austinthirdgen.org/mkport...SS_V8_vinE.jpg
If you need more diagrams, they are all here: http://www.austinthirdgen.org/index.php?pid=19
Hope this helps.
Lou
Hope this helps.
Lou
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
if the car is tpi, the SD tpi cars didn't have the buffer box. Instead, it was integrated into the ECM circuitry. The 90-92 TBI cars did, however, use the buffer box.
Car: 1991 Camaro RS 5.0
Engine: TBI 5.0L V8
I have a 91 RS 5.0 TBI. My speedo is dead and the cruise didn't work also. Check engine light was on and it threw a 24 code (VSS). So I replaced with a new VSS. Speedo is still dead but no check engine light anymore and the cruise control works now. What is the problem now? Buffer box or ECM? Thanks for any help you guys can give me.
Randomtask2
Sep 10, 2015 08:37 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
