Speedo is dead. New VSS already. HELP!!!
Old Aug 27, 2008 | 02:49 AM
bigbird90650's Avatar
Car: 1991 Camaro RS 5.0
Engine: TBI 5.0L V8
I have a 91 RS 5.0 TBI. My speedo is dead and the cruise didn't work also. Check engine light was on and it threw a 24 code (VSS). So I replaced with a new VSS. Speedo is still dead but no check engine light anymore and the cruise control works now. What is the problem now? Buffer box or ECM? Thanks for any help you guys can give me.
Old Aug 27, 2008 | 09:38 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Speedo is dead. New VSS already. HELP!!!
Good troubleshooting, kudos.
So we know that the buffer box is sending signal to the ECM and cruise module. Now you need to find out whether the speedometer doesn't work because:
1) the buffer box isn't outputting any signal on the wire to the speedometer
2) the wire to the speedometer is broken
3) the speedometer itself is bad
Do you have a friend with another 90+ Camaro with whom you could swap the instrument cluster for a minute? That would tell you if the speedometer is good/bad.
Also, do you have a friend with a TBI engine with whom you could swap the yellow buffer box for a minute? Again, that would tell you if the buffer box is good/bad.
Btw, was the speedometer always dead? Or when did it die?
If you still can't figure out what's wrong, I'm working on a simple and cheap VSS simulator that would help you find the problem. Right now it's in the drawing stage but hopefully I'll make one soon (this week).
Hope this helps.
Lou
Old Aug 27, 2008 | 01:23 PM
Engine: TBI 5.0L V8
Hope this helps.
Lou
I don't know anyone with a 90+ camaro to swap with. The speedo has been dead the whole time I've owned it (2 months now). Where is the buffer box located? Where can I get a new one? Thanks.
Old Aug 27, 2008 | 01:31 PM
BigBadLou's Avatar
Engine: TPI
The buffer box is usually next to the ECM, up in the dash on the passenger side. Not hard to get to at all. It's a bright yellow box, can't miss it.
Do a search here, somebody recently posted about the buffer box and where you can get one for a decent price.
In my opinion (from my experience), if two of the three outputs on the buffer box are good, I'd more suspect the speedometer or wire.
If your tachometer is out of adjustment and you'd like it fixed, you can send it to me and at the same time, I can test the speedometer to see if it works. PM/email me if interested.
Hope this helps.
Lou
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Gunner242
Dec 25, 2015 04:49 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
92projectcamaro
Sep 29, 2015 07:07 PM
