Wont Crank
Old Jul 23, 2005 | 01:15 PM
FyreBird's Avatar
Car: 1992 Firebird
Engine: 305 TBI -Tricked Out (320HP and counting)
Transmission: A4
Wont Crank
I have a 92 Firebird with the 305 TBI. I just rebuilt the engine and reinstalled it now the engine wont crank. Before I took the engine out it had a day where it would not start. It wouldn't do anything but tick once. That cured itself. Now I can't even get it to do that. I heard it may be the neutral safety switch. How do you bypass that to test? Also I used a voltage tested to see it there was any power to the fuse and when I turn the key to start the engine there is no power to the 3 amp crank fuse. I can put a screwdriver accross the posts and it will crank though. Thanks.
Old Jul 26, 2005 | 11:32 AM
FyreBird's Avatar
Car: 1992 Firebird
Transmission: A4
Neutral Safety
I just removed the neutral safety switch and ran a wire accross it. It will start when I do that. Does that mean that it was the switch or could it still be something else. I am getting a new switch to install tomorrow.
Old Jul 26, 2005 | 11:42 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You bypassed the switch and it suddenly works? I'd say it's the switch then.
Old Jul 26, 2005 | 11:52 AM
FyreBird's Avatar
Car: 1992 Firebird
Transmission: A4
It doesn't make sense though. It cranks in the on position when I bypass it. Not just in the start position on the ignition switch.I hope that is all that it is. Thanks.
Old Jul 27, 2005 | 01:02 PM
FyreBird's Avatar
Car: 1992 Firebird
Transmission: A4
Still Not Working
I put a new neutral safety switch in and it is still not cranking. Any ideas? I could bypass it by connecting a hotwire in the cluster to the purple lead to the starter, but i think that is all I accomplished. Let me know if there is something else that would result in the crank fuse not having juice on either side.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
