TPS Installation
Old Jul 24, 2005 | 05:04 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
TPS Installation
Ok I've heard numerous different answers , I've got a 92' Z28 5.7 TPI , is the TPS adjustable , cause I've heard that the 90-92 arent , leading to my question do I just install and plug in and that it ? , second question I tried to get a reading from the TPS and I cant get a reading at all , but there are like rubber insides of the connector so I dont think Iam making a connection , I need some help please!! , Also could someone explain how to set the idle speed??
Old Jul 24, 2005 | 06:06 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
I had to take a smal Dremel bit and egg the holes on my 91's to adjust it.
You should be able to plug it in and let it go. Mine wasn't off by more than a couple 10'th anyway.
Old Jul 24, 2005 | 07:57 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Thats what I was thinking but , how did you manage to drill it without damaging the wires , and also , are the 91-92 TPS adjustable or is that just the earlier ones??
Old Jul 24, 2005 | 10:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Only the pre 1990 TPS units are adjustable, the others are pre-set at the factory and are not adjustable. Another ploy to get your money if something goes wrong.
Old Jul 24, 2005 | 10:52 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ive seen in different places things called TPS enhancers they send a boost of volts to the TPS , and somehow its supposed to help performance ????
Old Jul 24, 2005 | 11:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
These so-called enhancers supposedly provide a faster response from the TPS to the ECM. I have seen no documented proof of this and would have to advise you not to waste your money on them. If someone on this board has any other documentation to support the claims of these products I would be interested in seeing it.
Old Jul 24, 2005 | 11:25 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Thanks Trickster you have AGAIN helped me out , I was going crazy cause like the article in TGO says to move it around to get a different reading and Iam like , IT DOESNT MOVE !!! , well I guess Iam just gonna buy another one , theyre not too expensive , and I cant adjust its reading anyway.
Old Jul 24, 2005 | 11:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
A word of caution when installing the new one. Do not overtighten the screws securing it to the throttle body. This would cause it to bind and not function correctly. The screws are only supposed to be a hair more than finger tight.
Old Jul 24, 2005 | 11:38 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ewwww , umm , that might be what I did on the last one!!! , well thanks for the warning I will definately remember that when putting the new one in, Thanks .
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 21, 2015 05:51 PM
mdtoren
Aug 16, 2015 05:45 PM
fonzie85
Aug 13, 2015 11:50 AM
