Short at Starter, help
Old Jul 25, 2005 | 09:59 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
ok im a dumbass and caused a short at the starter. i believe it was the starter because there was blue smoke coming from under the pass. side header.
i was cutting these wires from the old a/c harness which i dont need anymore.
i checked all the fuses etc. but they're all ok. i turn the key and nothing happens. does the starter has a fuse in itself or do i need a new one...? or is it something different?
thanks,
nebu
Old Jul 25, 2005 | 10:19 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
There's a fusible link to the starter about 5-10" away from the positive terminal.
Old Jul 25, 2005 | 10:26 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
you mean the big 30 amp fuse? its intact... like i said. i couldnt find any broken fuses. i dont get power anywhere. neither the underhood lamp, interiour light, gauges, nothing.
Old Jul 25, 2005 | 10:59 AM
Car: 86 T/A
Engine: HSR 355
No, I meant the fusible link.
Old Jul 25, 2005 | 11:16 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
this...?
*removed image*
Old Jul 25, 2005 | 11:21 AM
Car: 86 T/A
Engine: HSR 355
A fusible link is a piece of wire that blows when too much current passes. Its a fuse. Just follow the wires from the positive terminal to the starter. Eventually you will see a blown thin wire.
Old Jul 25, 2005 | 11:32 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What he is saying is look down at the starter solenoid and you will see a big wire coming from the battery and two to three smaller wires on the same large terminal post. The smaller wires are the fusible links that provide power to other parts of the car. One of them just happens to provide power to the A/C relay which you have cut out of the system. Judging from what you have said, I would have to say without a doubt that you cut two or more wires at once and didn't have the battery disconnected.
Old Jul 25, 2005 | 11:43 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
ahhh ok got it now. one of the smaller wires is blown about an inch away from the connection. is it possible to solder it together again or do i have to get a new one?
yes, i forgot to disconnect the battery. think this won't happen again
Old Jul 25, 2005 | 11:52 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You will have to get a new one and splice it in.
Old Jul 25, 2005 | 12:26 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
hmm ok how many ampere does this fusible link need to hold out?
Old Jul 25, 2005 | 12:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not sure how many AMPs there is, when you get one at the auto parts store just ask for a fusible link for a GM car. The package will have GM on the label to tell you which manufacturer it is for. Almost forgot, when you replace it, be sure to cut the wire several inches back from the break. Otherwise you will not have gotten all the old fusible link out and will still have the problem.
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
J.C. Denton
Sep 21, 2015 04:23 PM
sahlomonic
Sep 20, 2015 07:15 PM
Formula_88AE
Sep 3, 2015 01:47 PM
