Power wire to dist on a 87 IROC.
Old Jul 28, 2005 | 06:30 PM
Deuces Wild's Avatar
Car: 67 Chev Shortbox
Engine: TPI 383
Where do I draw power from to power the dist??
I have the small dist with the separate coil.
Has a pink/white wire in the dist plug?? I assume the white wire is the tach??
Old Jul 28, 2005 | 09:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It will be the pink wire in the gray connector on the ignition coil. This wire goes to the ignition switch.
Old Jul 31, 2005 | 11:51 PM
coolacts's Avatar
Car: 86 transam
Transmission: t700
if swapping from large cap with coil inside does this this wire go to the coil first then run another wire to the positive terminal on the small cap and the same with the tach from computer to coil negative and then to distributer cap beside power with the 2 prong connector ?
BRoss99
Aug 10, 2025 05:08 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
stalkier
Aug 13, 2015 12:59 PM
