Why Fuse Links?
Old Jul 31, 2005 | 08:46 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Why Fuse Links?
I read Jim's article on properly wiring electronic and electrical items and a point was brought out about fuse links. As much as a PITA the are, they are the only practical way to protect the vehicle wiring from catastrophic damage such as a fire. In most auto applications they are located at a point where the battery voltage is distributed to the harness and to the fuse panel. Links are preferred because they don't use a conventional fuse holder. Any time a wire has an inline fuse holder there is resistance in the connector within the fuse holder. A problem has always been in high current feeds that the fuse and/or holder gets hot, in some cases hot enough to melt the fuse and burn the holder contacts. Links eliminate this to a large degree especially in underhood environments. A common example is the household microwave oven. Open it up and you will see the primary AC fuse is ceramic, with a gold plated fuse holder. Put in a glass fuse and it will melt in short order. Another reason links are used is for liability reasons. Manufacturers know some idiot will use larger fuses in a circuit that may be drawing more current than normal or because of a chafed wire. By using links they can again protect the vehicle from excessive damage and the potential of a lawsuit. I doubt that you will see them go away any time soon.
Old Aug 2, 2005 | 08:35 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
good article, thanks
Old Aug 2, 2005 | 11:12 AM
S10Wildside's Avatar
Some fusible links have been replaced with Maxi fuses. For example, the 3rd gen electric fan is powered by a 16 gauge fusible link. The 4th gen electric fan is powered by a 40 amp Maxi fuse. Just making conversation.
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
thunder57
Nov 7, 2015 02:28 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
lanceflame44
Sep 25, 2015 12:28 PM
