INFL REST light after new steering column
Old Jul 31, 2005 | 05:18 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Is there any way to diagnose why the INFL REST light will not shut off? I just swapped out my steering column with another 90-92 column (which has proven to be a waste of time) and now the INFL REST light will not shut off.. I disconnected the battery, pulled the SIR fuse, disconnected the connector under the dash, then the connector at the airbag itself.. When I reinstalled I did the opposite.. reconnected at the airbag, reconnected under the dash, poped in the fuse, and then battery.. Started it and now the light will not shut off, blinks 7 times and stays on.. Any idea's?
Old Jul 31, 2005 | 10:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It basically means that there is a trouble code stored in the computer that is associated with the SIR system that needs to be checked and cleared.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Out-Cast
Aug 23, 2015 06:33 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
