temp sensor wiring
Old Aug 1, 2005 | 05:10 PM
Billy Bob 780's Avatar
Car: 1987 Z28 Camaro
Engine: 5.0 4 barrel
temp sensor wiring
Hi, can you guys out there help me further? my ongoing saga with my Z28 continues, I have ascertained that the temp sensor going to the thermostat housing is not receiving any power. Because of this the car overheated and it failed its emissions. Is this item run off a relay anywhere? If not any usual point where the wiring fails.Help! id like to use the car before our wonderful British summer over???
Old Aug 1, 2005 | 09:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
With the key in the "ON" position and the CTS harness disconnected, you should have 5 volts there. If you don't, then you either have a short in the wiring or a bad ECM.
Old Aug 1, 2005 | 10:53 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Don't forget the ossibility of an open wire.
Old Aug 2, 2005 | 05:16 AM
thanks guys please pray for me its not the ecm !!!!!
Old Aug 8, 2005 | 10:12 AM
I wish to say a big thank you to Damon, Sonix, Trickster & 2_point8_boy for all their advice my Z28 passed its Mot with flying colours I can now look forward to the rest of the summer cruising !!!! cheers
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
