Code 24 with autometer speedo and sender.
Old Aug 4, 2005 | 10:33 PM
Kurt04's Avatar
I have the covans cluster and autometer sender. I just pulled this code today, never gotten it before. The speedo seems jumpy. At idle its not in the zero area. It wont' go over 90 mph. Any ideas?
Old Aug 4, 2005 | 10:43 PM
Kurt04's Avatar
What does....
A code 24 should only be set while the vehicle is in motion. Disregard code 24 if set when drive wheels are not turning.
..mean?
Old Aug 6, 2005 | 05:34 PM
Vader's Avatar
Extraneous noise? If you have a scope, you can monitopr the VSS signal and see what's up.
Old Aug 7, 2005 | 10:51 PM
Kurt04's Avatar
No scope. Any other ideas?
Old Aug 7, 2005 | 11:29 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
I have the Covan's setup as well, but I had other problems and called Autometer customer support.
They were very helpful.
Contact info is on the Autometer website.
Old Aug 7, 2005 | 11:33 PM
Kurt04's Avatar
I might do that, because it is also throwing a code 14 (coolant temp sensor) but the guage works.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
