what is this relay?
Old Aug 17, 2005 | 05:01 PM
drptop70ss's Avatar
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
what is this relay?
When taking apart the dash on my 91 GTA there is a relay mounted behind the dash on the passenger side behind the mapholder area. It had two three prong sockets on it, and it was not hooked up to anything. I found the two connectors that I think went to it since they fit, one of them has a green wire that runs through the passenger side kick panel area with the ECM trunk of wires. Now from reading through the archives I assumed this was the starter enable relay which would be part of the vats system. Is that correct? If so how could the car start and run without it? I did not see any jumpers anywhere obvious, if this relay is jumpered out somewhere in the harness which wires would be tied together? I want to ohm them out and see if they are tied together somewhere I cant see. TIA!
Old Aug 17, 2005 | 06:27 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
May be the electric antenna relay or the Bose amp power relay.
Old Aug 17, 2005 | 06:39 PM
drptop70ss's Avatar
Car: way too many
you may be right on it being the power antenna relay, I never though of that. For some reason I had it stuck in my head that it was the starter enable because of the green wire, but I think you may be right.
##edit..just checked the car, there are 3 wires actually running out the fender from the relay, green, white, and grey, all around 16G. Sound like the wires to the power antenna?
Old Aug 17, 2005 | 10:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes that is the powered antenna relay. there are two connectors with a total of six wires. One has black, pink, and orange wires and the second one has the green, white, and gray wires you mentioned.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
