re-wiring
Old Aug 18, 2005 | 04:01 PM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
re-wiring
what must i do to make the 84' z28 inst.cluster work in a 90 rs i need a speedo bad
Old Aug 18, 2005 | 04:02 PM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
Re: re-wiring
Old Aug 20, 2005 | 07:35 AM
Vader's Avatar
There may be some different pinning in the I/P connectors - I'm not sure. The VSS will probably be an issue, however, since there were different types used between '84 and '90.
Old Aug 27, 2005 | 09:06 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: re-wiring
If you need a speedo real bad, go to the wrecking yard and get a 90rs speedo cluster. You will be much happier. In the end, a much easier and cheaper remedy. Set the 84 z cluster aside.
However, if you want to marry that 84 z cluster into the 90rs, grab yourself. Get ready for a project. What I suggest is based on personal experiance from converting my 87 700r4 / 5.7 IROC TO speed density, and all of the electronics that were required, including the mechanical to electronic speedo conversion.
BEWARE!!! If your 90RS is speed density reliant, removing the VSS will cause the vehicle to operate in constant open loop mode*.
(Assuming that you have a 700r4 in the 90RS) The 90-92's have an electronic vehicle speed sensor located where your 84's speedo cable hooks up to the trans. The pre-89 cluster is cable driven from the same location on the trans.
You will need to check and make sure that the VSS (vehicle speed sensor) on the 90's trans is a gear driven electrical unit. If so, ok.
Remove the electronic VSS from the trans. Install the gear driven cable/speedo unit from an 84-89 year model, and install a driven speedo cable assembly to the cluster.
When it comes to electronics and a few other things, Swaps and conversions from the 82-89's to the 90-92's are NOT really plug and play affairs! Too bad. Enough said.
Good luck.
MiTHRiL
Feb 17, 2005 10:06 AM
brannonh
Jan 26, 2004 03:37 PM
Syxx613
May 29, 2003 12:43 PM
