turn signal problem HELP!!!
Old Aug 19, 2005 | 02:11 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
This just happen about 2 days ago-when I signal right-the blinker works, however, when I signal left:
1.my front side marker doesn't have power
2.the front side marker has power but doesn't blink
3. finally, in the rear taillights, the blinker has power, but doesn't blink
*when I put on my lights, the left turn signal symbol is half dull in my dash display (but the signal isn't on)
thanks in advance
Old Aug 19, 2005 | 10:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To start off, points #1 & #2 in your post contradict each other. Next is a question, how do the lights work when you turn the flashers (hazards) on?
Old Aug 22, 2005 | 08:50 AM
91fbirdgta's Avatar
1 and 2 are what they are-even though its hard to imagine! My high beams work-didn't check it the side marker goes on or not, but will check . . .
anyone else?!?!?!?
Old Aug 22, 2005 | 04:34 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Sounds a little like the problem I had after painting my p.o.s. I didn't tighten down the lamp grounds very well and it caused all kinds of mystery lighting problems all the way to the point of causing the ar to run bad (idle) when the headlamps were on.
Start simple... Check, clean & retighten the headlight grounds on the rad. support, under the hood (just behind the lamps).
Old Aug 24, 2005 | 08:08 AM
camarorookie's Avatar
I had a similar problem. The blinkers would work though, but only with the headlights off. When I turned on the headlights the right turn signal indicator on the instrument cluster would stay on solid and the blinkers wouldn't work. It turned out that the thin film circuit on the back of the cluster had a small break. I soldiered it and the problem went away.
Old Aug 24, 2005 | 12:15 PM
91fbirdgta's Avatar
so you guys think there might be a faulty wire somewhere . . .
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
