How to properly power accessories?
Old Aug 19, 2005 | 11:28 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I've never gotten an actual answer to this question, and its starting to get annoying:
When installing stuff that needs a +12v source, and you DONT wanna splice into other wires or shove the wires up into the fuse block, WHERE do you get the power? I'm thinking about running a fairly thick wire from the battery to a bolt inside the car (just gonna take a small bolt and put an O connector on the cable and put it on the bolt), and then just put O connectors on anything that needs a 12v source and just screw it onto the main "bolt"....sorta a distrobution block sorta deal......but that doesnt seem like the BEST way to do it. What should I do? With all these gauges and other stuff i'm wireing up, its starting to get REAL messy. Thanks
Old Aug 20, 2005 | 12:04 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Speedingpenquin,
In answer to your question in the event that your car doesn't have one of these handy little units. You can go to one of the earlier third gen camaro's or firebirds and get one. It is known as connector C238 and is located behind the left kick panel up above the hood release cable. Should solve a lot of your power source problems.
Old Aug 20, 2005 | 08:34 AM
Thanks, i'll see what i can find
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
