hatch release gremlin
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
My hatch release button does not release when the ignition is on anymore.
It works just fine with the key out, just like before.
I noticed this shortly after a heavy rain storm got my carpets a little wet but I don't think that is the problem, or is it?
What gives?
What gives?
Your hatch isn't supposed to work with the ignition on. I think its a safety feature. Both of my cars dont anyway.
Adjust your t-tops so they dont leak. Water in interior is bad.
Take off the t-tops, take off the plastic piece in front by the windshield. Adjust the thing where the t-top rod inserts into.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Thank you trickster.
I never really tried popping the hatch while the car was running lately. I dont let my cars run anymore unless i'm in them. After having my 86 take off in reverse by itself because the linkage was not set right, i just dont.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Car: 91RS_92Z28
Engine: 5.0_5.7
Originally posted by Trickster
Yes the hatch release will work with the ignition on and the car running. However the hatch will not work at this time if the shifter is in any position other than "park" or "Neutral". On some models it will not work with the engine running unless the parking brake is set to the first detent.
i'm suspecting the switch on the hand brake that enables/disables you to use the hatch release switch when the car is running. Check that out.
Also, you can PM Trickster and ask him if he has the schematics for the wiring (if you need them).
also, check this out
might have a wiring guide:
https://www.thirdgen.org/techbb2/sho...release+wiring
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
