Turn signals and brake lights
Old Aug 25, 2005 | 06:32 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
This has probably been asked before, so bear with me please.
My car is an 83 trans -am with US spec lighting. Although i got my friend to give me an MOT certificate as is, the local constabulary might take a dim [no pun] view of my non-uk lighting.
So i'm going to see if i can sort something out.
Im going to use the 2 rear outer lights as indicators, ive got clear perspex and orange bulbs [they need to be orange and independant from the sidelights flashing].
So i need to stop the rear sidelights functioning as turn signals when the lights are on.
I can wire a feed from the front turn signals to supply the rears, [if anyone knows where to pick up a live from under the dash?] i've heard theres a feed from the brake light switch i need to cut and re-wire ?
If anyone can help or can point me to an article on this, it would be most appreciated.
Old Aug 26, 2005 | 12:20 PM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
Ok , anyone know which circuit\wire to look for that causes the front turn signal to flash, and the rears to flash the sidelights when the lights are on?
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
