blower motor problem
Old Sep 15, 2005 | 04:06 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Ok, I deleted my AC and installed a non-ac box w/ its respective blower motor. It seemed everything pluged directly in with no probs. only prob i ran into to the resistor was cracked on the non-ac box so i pulled it out and used the resistor from my ac box. After it was all together i flip the climate controls and i pop fuses! my interior lights go out as well as my stereo. I must have something hooked up wrong. Any sugestions or something obvious?
Old Sep 20, 2005 | 02:40 PM
Firebat's Avatar
maybe the resistor you swapped out is different between the two boxes. Try to get one for non-ac and they try it again.
Old Sep 20, 2005 | 04:45 PM
easier said than done... where an i gonna find one of those?
Old Sep 20, 2005 | 07:18 PM
Firebat's Avatar
go talk to your gm dealer...it will probably cost too much though
Old Sep 20, 2005 | 07:21 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Any jobber should be able to get you the blower motor resistor, AutoZone even. But check to see if the a/c car and non a/c car use different resistors before you waste your money.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
