can i re-wire my head lights
Old Sep 17, 2005 | 11:47 AM
Tweaked's Avatar
Car: 88 t/a red w/body kit
Engine: 305tpi...355 carbed
Its always somthing with my car. so now its running decent. and i rebuil the head light motors and tested them on a battery worked great. test the terminals on the car test good. hook them up passenger side works drive side NOTHING. light works motor won't.... i tried to just splice the wires cuz i thought the harness might have been bad... no luck. so can i run the leads from the passenger side to the drive side?!?!?!
what might be the problem??
Old Sep 17, 2005 | 11:51 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I did this & it works wonders!
https://www.thirdgen.org/newdesign/t...tupgrade.shtml
Old Sep 18, 2005 | 10:10 AM
Vader's Avatar
I'm not certain what model year was the first to get the single headlight door control module, but your's is close. It may still have the three relay system. If so, check the isolation relay on the left side. You can probably exchange the right and left relays, and see if the problem moves. A new relay is about $10 USD. If your's has the single control module, a new moduile is a lot more expensive.
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
