hi-beam switch
Old Sep 19, 2005 | 11:05 PM
wkracing2000's Avatar
hi-beam switch
does anybody have any info on how to replace the high-beam switch in my 1990 r/s
Old Sep 19, 2005 | 11:20 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
If it's like the 91-92 models, it's way down low on the steering column itself maybe 8" away from the firewall. All the ones I've seen are small white plastic units. Hard to get to, but not too difficult to swap once you're there. There should be a little adjusting screw which when loosened will let the switch slide toward and away from the HI/LOW selector lever. Make sure you set it & test it a few times before tightening everything down and bolting all the panels back together.
Old Sep 20, 2005 | 10:09 PM
how do i get to it do i have to take off the steering wheel and go in that way
Old Sep 20, 2005 | 10:16 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Start off by removing the two panels underneath the steering column. I'm not completely certain if the switch can be reached with the column in place, but I do believe so.
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
