Starter not stoping
Old Sep 22, 2005 | 12:38 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Starter not stoping
Hello every one! I got a problem when I start my car the starter doesn’t stop trying to start when the car is started, and even if I take the key out its still going so I got to get out and disconnect the battery and when I reconnect the battery the starter doesn’t start going. The starter is new. What do you think?
Old Sep 23, 2005 | 10:57 PM
UnderKule's Avatar
Car: 91' RS Camaro, 05' Stratus, 02 quad cab Dakota
Engine: 305 in the Camaro
Stupid question but there is a purple and white wire that goes to the solenoid. You didn't accidentally hook it to the main post or the wrong side of the solenoid did you?
Other than that i would have to get into my service manual to see where you could be getting power from. What year is your car and does it have the VATS (anti-theft system installed/ key with the resistor in the middle) If so there is a starter enable relay behind the driver's side kick panel that could be bad.
J.P.
Old Sep 28, 2005 | 06:07 PM
Car: 89 GTA
Engine: L98 350
I got the battery cable and two other red wires going to the main post I think I put the purple and white wire on the right one. Its an 89 GTA so it does have the VATS how do I test the starter enable relay and what does it look like?
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
