swapping to Vbelt ????
Old Sep 24, 2005 | 12:58 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I'm swapping out my serpentine belt system to vbelt. I'm using the system outta my 79 GMC pickup. I'm curious if my alternator from my serp will work with my vbelt brackets? Obviously I need to change the pulley. But will the bolt holes line up?
Old Sep 24, 2005 | 10:28 AM
UnderKule's Avatar
Car: 91' RS Camaro, 05' Stratus, 02 quad cab Dakota
Engine: 305 in the Camaro
First, Why would you even want to switch to a V-Belt? You lose alot of efficiency that way. Plus if you are looking for more HP out of your setup, the serp belt is the way to go.
2nd If your car is pre 1987 than you may have a chance that everything will line right up with no probs but you may have some spacing problems after 1987 because certain things were changed that year on the SBC as a whole.
J.P.
Old Sep 24, 2005 | 11:39 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Well there are a couple reasons I'm switching. I wanna clean up the clutter in my engine bay and drop some pounds. I'm losing the a/c and I don't want to spend a fortune on the delete pulley. I have the vbelt setup minus alt. and the engine is a pre-87.
Old Sep 25, 2005 | 04:04 PM
UnderKule's Avatar
Well then it should go together well for you. Just watch the alignment of the pulley's if it is off just a hair you will go through belts left and right. Once you get it going i would always carry a spare just in case one of the pulleys takes a bite out of the belt.
Good luck,
J.P.
March makes some excellent bracket and pulley set-ups that are fully adjustable. That's what i am using and i have never worn out a belt yet.
Old Sep 26, 2005 | 02:46 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Thanks J.P. Eventually I'd like to make the March Leap. But that will be a ways down the road. Other priorities at the moment. Car needs a diet for now.
Old Sep 27, 2005 | 08:12 PM
88TAJeff's Avatar
Car: 88 T/A
Trust me, you won't spend a fortune to get a good used delete pulley from the wrecker. They usually even have them all on a shelf somewhere. Mine was 20.00 CAD.
Old Sep 28, 2005 | 09:36 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I'll call around and see if I can find one. What kind of power losses am I looking at swapping to vbelts? Seems like vbelts are as welcome as prostate cancer on this board.
Old Sep 28, 2005 | 10:30 PM
88TAJeff's Avatar
Car: 88 T/A
Well, I'd def like the v-belts more than the examination!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
