best replacement alternator
Old Sep 27, 2005 | 11:30 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Assuming the alternator is dead on my car, what is the best replacement for my 1991 GTA? I don't want something that robs too many horses from my bird, but I dont want something that is going to give lousy output either.
My car is pretty much stock now, but I am looking at beefing up the horsepower and improving the handling. Will this make a difference in my selection of an alternator?
The only potential non-performace accessory I can see adding in the future that would draw a significant amount of amps would be a couple of subs. I dont think I need a beefed up alternator for that, do I?
Thanks again!
Bill
Old Sep 29, 2005 | 06:02 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The stock 105 amp unit should be sufficient. Much more depends on the battery's amp/hour rating. If you add some more demand such as with an amp just get a higher capacity battery. The generator only maintains the battery, the battery itself really determines how much demand you can place on the system.
dutch930
Sep 11, 2015 06:58 AM
Cleotiz
Aug 23, 2015 12:07 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
