timing frustration
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
timing frustration
Hello
I have a problem with base timing in my car (89 Trans AM 350 TPI stock) I disconnect ESC connector and connect the timing light.
The light flashes from 4* ATDC to 14* BTDC or more (furious and insane =]) I cannot set to stability timing. It's very amazing because idle is very well, reaction for pushing gas pedal
and all over perfomance is good too.
I pulled the dizzy and check the ->
-pickup coil
-ignition module
-ignition coil
things done ->
-cleaned from rust and inspected the reluctor
-new cap and rotor
-new spark plugs
-new wires
ECM not throwing trouble codes.
car not overheating, I drove 2h yesterday and no pinging and SES light from knock sensor...
I haven't got any idea
thanks for help
-pickup coil
-ignition module
-ignition coil
things done ->
-new cap and rotor
-new spark plugs
-new wires
thanks for help
timing frustration
You may want to consider the possibility of a mechanically worn distributor. Worn bushings, loose or worn gear, and a loose reluctor may cause those problems.
