ignition switch auto or manual
Old Sep 30, 2005 | 10:28 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
I’m doing the ignition switch in my 89 firebird and I have recently changed the auto out to a T-5. Do I go with the auto ignition switch or the manual ignition switch? And is any ones ignition switch held in by one Phillips screw? Because mine is and I don’t see how they could get a screw driver in there.
Old Sep 30, 2005 | 11:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Actually there is not a seperate ignition switch for the manual or automatic transmission. What you will be looking at is wiring up the clutch start switch when you do the swap over. BTW, the wiring is already there for the switch when you install it.
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
