Advise on Wiring Throttle Kicker Solenoid
Old Oct 1, 2005 | 10:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd like the idle to bump up when the A/C is turned on and return to curb idle when turned off. As is, the solenoid is energized with the ignition regardless of whether the A/C is activated or not. The relay and solenoid are new. The computer has been removed as well as the 10 amp fuse that controlled it. Here's the wiring diagram:
http://www.geocities.com/vtcamaro/Pi...rams/pg145.jpg
I joined, as an experiement, the green wire from the pressure cycling switch to the blue wire of the solenoid. In this configuration, the solenoid functioned as I wish, but I'm somewhat leery that that 'fix' without a relay would cause problems.
Suggestions would be much appreciated.
JamesC
jklein337
Sep 19, 2018 06:23 PM
fasteddi
Sep 2, 2015 10:29 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
