Won't start
Old Oct 2, 2005 | 09:34 PM
Kurt04's Avatar
Won't start
The key switch will not engage the starter. I have a new starter and just put in a new ignition switch. I have adjusted it all the way. I can even pull the rod as hard as possible but nothing. I can jump the starter to the battery to get it to start.
The only thing I can think of is wiring, but i dunno what wires to track down.
Old Oct 2, 2005 | 11:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Start by checking the two red wires at the ignition switch to see if you are getting any power to them. Then I would check to make sure I put the purple wire from the park/neutral switch on the small post marked "S" on the starter solenoid. If there is no power to the ignition switch then it is obvious that you have a bad fusible link at the starter solenoid.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
