Fuse trouble
Old Oct 5, 2005 | 05:57 PM
primus2010's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7L V8
Transmission: T5 world class 5 speed manual
Fuse trouble
I have an 87 Trans Am GTA, the INJ1 fuse blew, which killed the engine. I replaced the fuse and after some trouble finally got the engine to start, but its almost as if the timing is off, or its miss-firing on one or possibly two of the cylinders. The oil pressure is all but gone, even though it has less than 400 miles on the new oil change. I pulled the dipstick and the oil level is slightly low, but not low enough to give an inaccurate reading. I pulled all the spark plugs and they are clean, double checked the firing order from the distributor, and checked the rotor in the distributor cap, everything looks clean and good to go. If anyone has any info that can help me out it would be much appreciated.
Old Oct 5, 2005 | 07:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you checked the wiring for the injectors to find out why the fuse blew in the first place? Are you getting a pulse signal to all the injectors?
Old Oct 6, 2005 | 09:35 AM
primus2010's Avatar
Engine: 5.7L V8
the pulse over cylinders 5 and 7 is gone, just found that out last night. is there a way to fix that or am i going to need a new wiring harness all together?
Old Oct 6, 2005 | 02:44 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Repairing the wires should be no problem. Theres a million different ways to do that. I prefer the soldered method, however a crimp connector will work. The hard part will be finding where the wires are damaged.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
