Unusual Brake light problem
Old Oct 6, 2005 | 10:06 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I just bought an 89 Iroc last week.
Today I noticed when I step on the brake, both turn signals lite up.
Also some of the dash gauge light lite as well.
It is the strangest thing.
Anyone heard of this happening before?
I'm open to suggestions.
Old Oct 8, 2005 | 08:46 AM
Vader's Avatar
Verify good grounding at the brake lights. There may also be a problem at the turn signal switch. The dash lights illuminating sounds like a poor ground or cross connection somewhere.
Old Nov 29, 2005 | 09:40 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Well I found what the problem was quite by accident today.
I replaced the tail light/brake light bulb and the problem disappeared.
After I realized the problem was fixed i measured the bulb with an Ohmmeter and found that the 2 filaments in the bulb were shorted together.
Just thought I would follow through this problem with the solution.
Old Nov 30, 2005 | 11:45 AM
Vader's Avatar
Thanks for the follow-up. That would be an odd one.
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
