Fuel Gauge
Old Oct 8, 2005 | 05:03 PM
Code's Avatar
Car: 1989 Black Pontiac Firebird
Engine: 2.8l V6
Transmission: Automatic
Axle/Gears: Stock Crap
Fuel Gauge
It is STUCK in the Full Position(Way Past F)....I got gas and filled it up....But have gone over 100 miles now...Gauge still reads PAST FULL? is there a way of reseting this thing? without pulling the dash apart and pulling cluster?
Old Oct 8, 2005 | 06:11 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Guage or sending unit is perhaps faulty.
JamesC
Old Oct 8, 2005 | 11:17 PM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
Transmission: 5 speed
I have an 86 Iroc and had the same problem. Got underneath the car and found that the ground to the fuel tank electrical stystem was unplugged. The ground is in front of the fuel tank and when you scoot underneath the back of the car it is easy to see because there is a big gap.
Hope this helps ya out.
Old Oct 8, 2005 | 11:19 PM
Code's Avatar
Engine: 2.8l V6
Thanks...... ill be darned.....
Old Oct 10, 2005 | 07:02 PM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
Did that work for you?
Old Oct 11, 2005 | 08:48 PM
Code's Avatar
Engine: 2.8l V6
Nope.... still stuck on full.....
Old Oct 11, 2005 | 09:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
BTW, the ground point for the fuel tank in your car is under the carpet behind the right hand rear seat and not on the tank.
Old Oct 11, 2005 | 09:33 PM
Code's Avatar
Engine: 2.8l V6
Trickster,
Yeah, i got a manual on the car. I looked. All is normal with the wiring.......Freaking driving me Nuts... lol. Thanks for the Reply.
Old Oct 11, 2005 | 09:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well, if you have a manual on the car and there isn't a problem with the wiring. Then that leaves you with one of two assumptions. 1. the guage is bad or 2. the sending unit is bad. Did this problem just suddenly occur or have you had it for awhile?
Old Oct 11, 2005 | 09:59 PM
Code's Avatar
Engine: 2.8l V6
Yes, I agree on the 2 ideas you stated. It just started....I filled the bird up with gas, went over 100 miles, it's still on full. If i can find a gauge for the cluster, i'll get one off ebay. The sending Unit is another story. Don't look like fun to have to rip the tank apart to get to it. However, I been saying that about every project on this car and all I do it keep Learning...so...It's all good. I just got this car 3 months ago, and it's been a non-stop project. However, that is why i bought it...Project. Almost there...Just glad i stumbled accross this Board\Site ... I run a Motorcycle website, However I sold my bike...LOL so now it's on to my Bird!
Weeeeeeeeeee Off to find a cheap gauge!
Thanks Trickster......
Old Oct 13, 2005 | 03:43 PM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
I wouldnt go buy a new guage untill u r absolutely sure that that is what u need. For surely its not the sending unit if your car is running. If your sending unit was gone you probably would not be able to start your car. Im still stuck on the theory that it is a bad ground. Did the fuel gauge in your car act erraticaly (bounce up and down) before it got stuck on full? Did you scoot under the car from the back inbetween the exaust pipes infront of the fuel tank and see the cable coming out of the top of the gas tank that connects to the frame, unibody? Is it unplugged? Your car will still run if this ground is dissconnected. If it is dissconected than your fuel gauge will be stuck on full like mine was. I just plugged the ground back in and my fuel gauge worked right away. I understand your frustration as I went through the same deal and had my car dieing all over the place cuz i was unsure how much fuel I had. If you have to ask a couple questions to find this ground ill be happy to ansewer them. Did you actually find the ground? IF you did and it was connected try unplugging it then plugging it back in. Maybe that will work. Hope this helps and hope youve located this ground as this is most likely your problem. Also inspect this ground wire for deteriation and also make sure the ground pluggin on the frame has not worked its way loose from the frame. Hope to hear a reply soon.
Old Oct 13, 2005 | 04:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have to disagree with Irocstang on his comment "that if the sending unit was bad the car wouldn't run". The sending unit and the pump are two seperate units and wired seperately. If the float on the sending unit was stuck in the full position, then the car would read full all the time. If the plug on the tank was disconnected then the car wouldn't. By the same token, if the ground for the tank was bad then the pump wouldn't operate either. So that leaves him with the option of a bad sending unit, a bad guage, or a bad wire from the sending unit to the guage. He could also try tapping on the fuel guage to see if it moves.
Old Oct 13, 2005 | 04:10 PM
JamesC's Avatar
The sender controls the guage.
JamesC
Old Oct 13, 2005 | 11:35 PM
Code's Avatar
Engine: 2.8l V6
no ground issues.... i tried the tapping on the guage... nothing...still stuck! i have not taken the dash apart to get the the guage, but that's my next feat.... To answer the ? about bouncing guage nope no problems until i filled her up and the guage stuck....all else fails GET a bigger hammer... ... might scare it into working ~
Thanks Guys, When i find the issue i will post it...this is a weird one.
Greg
Old Oct 15, 2005 | 12:10 AM
ivirscar's Avatar
Car: ???
Hey Greg...
Check the resistance between the sending unit and GROUND. It should read anywhere between 0~90 OHMs... If you've already driven 100 or so miles, my guess would be a reading of roughly 50 OHMs now...
Brenon
Old Oct 15, 2005 | 10:40 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by ivirscar
Hey Greg...
Brenon
That's assuming the float isn't stuck in the full position. This happened after he filled his tank.
Old Oct 15, 2005 | 10:57 AM
ivirscar's Avatar
Car: ???
Exactly! So if the reading is STILL 90 OHMs and his tank is HALF FULL, then he'll know that he needs to REPLACE the sending unit!
Old Oct 15, 2005 | 11:04 AM
Code's Avatar
Engine: 2.8l V6
Will check that today and report back, man what a bummer...LOL... thanksGuys I have a feeling WE will get to the bottom of this...
Greg
Old Jun 18, 2009 | 06:18 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Fuel Gauge
Any updates? My fuel gauge is stuck in the Full Position(Way Past Full) after I filled up with gas
Old Sep 27, 2011 | 10:09 PM
anteeeze's Avatar
Re: Fuel Gauge
Very old post but I found that the negative ground on gauge had no connection on my 89 iroc with a pegged full gauge just rarn the neg from another gauge and eureka!
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
