Alternator.
Old Oct 19, 2005 | 07:14 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
Alternator.
Okay, i had bought a new alt. in 2003 for a 1968 Chev pickup, wellt the pick was a rust bucket, and i was offered a 1983 camaro berlinetta for free, needed engine and tranny, so i put the 68 chev pickup 350 engine in the camaro, One Slight problem, everything else went together like cake.
The alt i had bought in 2003 i wanted to use because it was new and worked like new, and the alt that came with the car looked like S***, so anyway theres a connector on the back of every alt, with two wires, one is ground and the other is black and goes somewhere regulator? well the connector on the camaro is like this - - and the 68 chevy 2003 alt looks like = can you see my problem, I remember i looked at which wire went to the ground and to the regulator on both alts and i pulled out the wire with female connectors still attached and swaped the plastic connectors so i could use the new alt. in the camaro.. Does any one understand any of this?
Old Oct 19, 2005 | 07:18 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
oh and i forgot to mention, i am not getting any kind of charge when it idles or by reving and the headlights draw alot of juice, so the alt isnt working.. well the 2003 alt has a lifetime warranty so i went down today traded it in for a new one, a not a thing has changed, so maby the 2003 alt wasnt bad....
Old Oct 20, 2005 | 03:34 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
If you know where the old wires went, check this out:
http://www.autoshop101.com/trainmodu...or/alt101.html
On the 3rd or 4th page, there is a wiring diagram. Sounds like you didn't connect the excitation circuitry properly. Typically, you would connect a small gauge wire from the alt back to the battery (+); make certain it is switched so it only comes on with the key.
Old Oct 20, 2005 | 05:11 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
well i did do that from the terminal + to the Pos. post on the alt,
then the wire connector looks like l l well, one wire is black, then the other wire is white and goes to the ground post on the alt. after finding out the alt didnt work i figured i'd run a neg wire to that post, it didnt change anything.
SRKLEGIN
Oct 29, 2015 06:38 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
R13_Braz
Sep 18, 2015 05:00 PM
elevario
Oct 15, 2001 03:20 AM
GuyRicardo
Aug 10, 2001 11:07 PM
