Simple vats question!
What entirely does vats disable??As of right now my fuel pump kicks on,security light stays on,i have ecm code 53,turn key no start crank or anything,no fuel swirt from injectors during priming!!So does it disable the injectors too??
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The two items controlled by the VATS control module are the starter through the starter enable relay and the fuel injectors through the ECM.
