fog lights quit in 1989 GTA
Old Nov 3, 2005 | 08:21 PM
walrus108's Avatar
Car: 1989 GTA White Hardtop
Axle/Gears: 9 bolt 3.27
My foglights just quit for some reason. The drivers side has recently burnt out. After I replaced the bulb I tested it and it worked fine. But now, about a week later, neither one will come on. Is there a fuse for the foglights? Where is the relay and how do I test it? Since I have to fix them anyways, should I rewire them at this time? I did a search on "foglights" and read through 10 pages of results and still found no clue as to diagnose my problem. Thanks for any help you can offer.
Old Nov 4, 2005 | 04:08 PM
walrus108's Avatar
No one knows if there are any fuses or breakers to check and where they're located?
Old Nov 4, 2005 | 06:50 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
yeah, there's a fuse block behind the driver's side hush panel. Try there first. I'm pretty sure there's a fog light fuse.
jaridjohn
Jul 8, 2024 03:49 PM
89GTAOz
May 16, 2020 09:31 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
