Ignition System
Old Nov 4, 2005 | 06:35 PM
redroc88's Avatar
Car: 1988 Iroc
Ignition System
I want to upgrade my stock ignition and i already know i'm getting accell 8.8 spark plug wires and an msd 6AL box. what other msd parts will be effective with the 6AL? I'm still running my computer, so the HEI upgrade kit isn't gonna work. What about blaster coil? distributor cap? anything else that could help?
Old Nov 4, 2005 | 06:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why do you want a 6AL? If you're going to use it, then about the only other thing you might want to upgrade would be the coil.
Old Nov 4, 2005 | 06:53 PM
redroc88's Avatar
Car: 1988 Iroc
the 6AL is the best valued ignition part, for what your getting... but your saying the 6AL plus the blaster is all that's needed?
Old Nov 4, 2005 | 07:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, I'm saying that the 6AL probably isn't going to give you any benefit (apart from the rev limiter) on a relatively stock engine that you couldn't get from something like an aftermarket ignition module.
Old Nov 4, 2005 | 07:56 PM
redroc88's Avatar
Car: 1988 Iroc
- what aftermarket ignition module would you suggest?
Old Nov 7, 2005 | 02:05 PM
crazymex83's Avatar
Car: '88 Firebird Formula 350
Engine: L98 TPI 350
Transmission: 700R-4
I installed a Crane HI-6S ignition system into my '92 Blazer and it came with the matching coil, piggyback wiring harness, ignition system and a few pieces of mounting harware. Basically, the system was plug and play and I just had to remove the old coil to install the crane coil along with mount the ignition box. I didn't have to splice wires or anything, plus it has a built in rev limiter. If I remember correctly it will work with any external coil setup from '88 till '95. Besides, it only cost me $190 or so all together and only took about an hour to setup.
Old Nov 10, 2005 | 05:56 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
the 6al is a good box, i kno a dude who is running one inhis 1970 roadrunner with a 426 and it works awsome.
if it didnt pack enough power to make a difference in perfomance, he wouldnt be running it...
Old Nov 10, 2005 | 06:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The 6 series boxes are just fine if you're running high RPMs or high cylinder pressures in a modified engine. For just about anything streetable though, your money is better spent on something else.
Old Nov 17, 2005 | 08:11 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Can U Get An Aftermarket Ignition Module For A Stock Distributor?
Hotrodboba400
Dec 10, 2019 07:07 PM
MM2Robinson
Oct 1, 2017 09:16 AM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
