Hookers + wiring = stupid Q?
Old Nov 8, 2005 | 03:01 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Ok soo I put some hooker LTS on the car and burnt up my pos battery cable ok no big deal got a new one now trying to figure out best way to keep from toasting it again (60 bucks a hit).
So now comes the retarded question of the day. Can I wire up the other wires that go to the post on the starter (red with brown fusable links) straight to the battery or alternator? Doing so would give me alot more room between the headder and the block to play with for my POS battery lead so I can actually drive the car for more than a week
Any help is appreciated.
AL
Old Nov 8, 2005 | 06:04 PM
Firebat's Avatar
if those wires connect up to the alternator and battery, i dont see why you can't relocate them. Just to give an example, on my LT1 engine swap project, the wires for fusible links connect almost directly to the battery, dont connect to starter, but thats the way LT1 wiring is.
Old Nov 8, 2005 | 06:27 PM
Car: 89 Formula
No they go from the starter to the ignition switch I believe I want to know if i can run them directly off the alternator or battery instead of the solonoid
If i can Ill do that instead of getting a remote solonoid
Old Nov 9, 2005 | 07:41 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
there should be only one for the ignition switch going to the solenoid. the others come off the pos batt post on the starter itself, basically directly off the battery...
Old Nov 9, 2005 | 01:34 PM
Car: 89 Formula
So I can wire thoes directly to posative and not have a problem?
Old Nov 9, 2005 | 03:38 PM
91_T/AWS6's Avatar
Car: 91 Trans Am
Yes, the solenoid is just something to act as a switch for the starter with the one side being hot and the other neutral. It has the smaller posts for hooking up accessories instead of haveing to get those big round washers on the end of the wires so it can crowd up the post on your battery.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Cleotiz
Jan 6, 2018 08:56 PM
deracer
Apr 11, 2016 12:04 AM
formula_novice
Sep 5, 2015 03:58 AM
tricky1
Aug 23, 2015 01:17 PM
