Low voltage???
Old Nov 16, 2005 | 01:06 AM
Slowmaro91RS's Avatar
Car: 91 Camaro RS
Axle/Gears: 10 bolt posi/3.23
Low voltage???
I've been noticing that my voltage has been really low for the past few days so I decided to change my alternater. After I put the new one in I still had very low voltage (11 - 12 volts). Tonight coming home from work my voltage dropped extremely low and my car stalled out. I got it jump started and made it about 2 miles before it happened again. I checked my alternater fuse and i have voltage to all 3 wires coming from it. Since my motor is an 88 and my car is a 91 is there something I forgot to do to change the wiring over? Now my car doesn't seem to charge at all with either alternater. Can someone please help me???
Old Nov 16, 2005 | 01:28 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Check votage at the alternator. That should be around 14v. You may have a bad alternator cable. Did this problem start right after the motor swap? Check that all your grounds to the motor are hooked up too.
Old Nov 16, 2005 | 01:49 AM
Car: 91 Camaro RS
The voltage I listed was checked at the battery and tyhe alternater. All my power and grounds are new 4 gauge. This problem just started a little over a week ago. I've had this motor in and running since spring now. what would cause the alternater to only put out 11 - 12 volts? Both did the same thing and both were relatively new. I know the problem has to be in the wiring somewhere but where do I look and what do I look for?
327IROC85
Sep 23, 2015 12:11 AM
gta_knight
Sep 17, 2015 03:48 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
