C207 Diagram request
Old Nov 17, 2005 | 11:33 AM
Firebat's Avatar
Looking for C207 diagram/schematic/pinouts.
Old Nov 17, 2005 | 02:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What year, make, & model? Also what engine is in it.
Old Nov 17, 2005 | 02:20 PM
Firebat's Avatar
86 Trans Am, LG4, 4 bbl carb, VIN H
Old Nov 19, 2005 | 06:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here you go, sorry to have taken so long. Things have been interesting here lately.
Pin “A”:Air select valve (brown wire)
Pin “B”:Fuel pump relay to ALDL (orange red/black wire) VIN F, FP/CLTR fuse to Fuel Pump Relay (orange/black wire) on VIN 2
Pin “C”:Light driver module (white/dark green wire)
Pin “D”:Fuel pump control fuse (black/orange orange/black wire)
Pin “D”:Fuel pump to fuel pump relay (white light blue wire) VIN F
Pin “E”:ALDL connection (white/black wire)
Pin “F”:Engine ECM fuse (pink/black wire)
Pin “F”:ECM IGN fuse to ESC module & ECM (pink/black wire) VIN F
Pin “G”:MAS module & emissions (pink/black black/pink wire) “Automatics only”
Pin “G”:Back-up switch (dark blue wire) “Manuals only”
Pin “H”:TCC to ALDL (tan/black wire)
Pin “J”:Crank fuse to fuel pump relay (purple purple/white wire) VIN G
Pin “J”:MAS module to ALDL (orange wire) VIN F
Pin “K”: VSS (brown wire)
Pin “L”:Fuel tank to fuel pump relay (tan/white)
Pin “M”:Engine ground (black/white wire)
Pin “N”:Park/Neutral switch (orange/black) “Automatics only”
Pin “P”:Brake switch (purple wire)
Pin “R”:Crank fuse to cold start switch & injector (purple/white purple wire)
InfernalVortex
Apr 20, 2021 11:31 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
wstephan96
Sep 25, 2015 04:28 PM
