headlight dome light and guage lights
Old Nov 22, 2005 | 11:23 AM
charlie0915's Avatar
my 89 CAMARO RS ORIGANNLY HAS 2000 MILES ON IT AND MY HEAD LIGHTS DOME LIGHT AND GUAGES LIGHT DOES NOT WORK HOW CAN I GET THEM TO WORK THEY WORKED 3 DAYS BEFORE MY GRANDPA PASSED AWAY AND NOW THEY DONT WORK IS IT A FUSE OR SOMETHING PLEASE
BOY IN NEED
Old Nov 23, 2005 | 02:22 AM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Re: headlight dome light and guage lights
Obviously, your car is in mourning. (sorry, couldn't resist.)
Your fuse block is located directly beneath the driver's side gauge cluster. Depending on if you have hush panels or not, you may have to unscrew a small panel that has "FUSES" written on it. If there are no panels on the underside of the dash, just look for a little 5x5 inch box with little multicolored chips inside it.
Pull the fuses out one at a time and see if the little wire in the center of the fuse is burned through. If it is, replace with a new fuse of the same amp rating (they're also the same color). If not, put the fuse back in the same place you took it from.
If, after replacing any burnt fuses you found, the lights still don't come on, check the fuses again. If the same ones burned out, your car has a short somewhere in the wiring, and troubleshooting that is going to be a royal pain in the doohickey. If it comes to that, I'd enlist the help of someone you know who is good with electronics.
Old Nov 29, 2005 | 09:33 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
if it is not the fuse it is usually the remote dimmer switch that is in the dash on the right side of the colluum
Old Dec 2, 2005 | 10:53 AM
kev2318's Avatar
Car: 85 firebird se
Transmission: auto.
does your door locks work? becauase i had the same problem. for me it was the connection running through the firewall in to the car all it needed was to be tighten back down
Old Dec 2, 2005 | 10:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Jamon8, that little function was peculiar to firebirds only. The camaro's did not have that incorporated into its design.
Old Dec 3, 2005 | 07:30 AM
jamon8's Avatar
Engine: 350 tpi
thanks trickster. I need to pay attention to the make and model of the car before I reply. I have had 6 third gen firebirds and no camaros. Thanks again
Old Jul 20, 2006 | 11:36 AM
prostar's Avatar
Car: 1986 IROC-Z
Engine: 355
Transmission: TH700R4
Axle/Gears: 3.42 28 spline zexel
'86 camaro light issue
Hey guys,
I've got an '86 Camaro (IROC) that has this exact problem. When I was bringing it home from storage in the spring all the lights died. Everything controlled by the dimmer (head, dash, heat, dome).
Where does the power source for the dimmer come from? I've checked the fuses. I have the haynes manual and thier diagrams suck.
Old Jul 20, 2006 | 05:15 PM
Tripper511's Avatar
Car: 1982 Trans Am
Engine: 350 4BBL
Transmission: 4 Speed Manual
I had the same problem in my trans am and I happened to be my cigarette lighter. All I did was unhook it and the lights worked. I guess it was grounded. You could check that. As a last resort you can get the chilton or haynes manual and follow the electrical path for that fuse and check each light one by one until you find the problem.
Old Jul 21, 2006 | 08:03 AM
prostar's Avatar
Car: 1986 IROC-Z
Engine: 355
I have the haynes manual. The diagrams do show what's connected to what, but there is no indication of where things are located. Plus there's no legend. What the @#$% does SXL GXL mean? I assume the numbers like 3.0 .8 etc... are the size of wire. I also assume the 10 digit numbers are GM part numbers. It's easier to just figure it out without the haynes BS.
Oh yeah, I measured the cig lighter for a short, it's fine.
Old Jul 21, 2006 | 09:23 AM
prostar's Avatar
Car: 1986 IROC-Z
Engine: 355
Thanks for the help guys. Turns out it was a fusable link at the solenoid. No idea why it picked that time to blow. What a PITA because I broke my solenoid trying to get the wires off.
1992CamaroGirl
Dec 25, 2017 08:45 PM
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
