Does ECM control shift points! Revv limiter??
Old Nov 22, 2005 | 07:52 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Question??
I can't revv over 1000RPM with the brakes on, I was wondering if the ECM had anything to do with this!??!?!?
Old Nov 23, 2005 | 01:42 AM
Firebat's Avatar
are you in neutral,park, or in gear?
Old Nov 23, 2005 | 10:00 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
nope. trans is controlled only by the detent cable. Could be that the converter is locked up, but it should unlock itself when you touch the brakes. Sounds like an ignition problem.
Old Nov 23, 2005 | 12:51 PM
thats what I thought too!
How would you suggest I go about testing my ignition!??
So far I have
new
MSD coil
MSD cap and rotor
distirbutor
new pluggs
new wires
all new sensors
re-built TBI
And this did happen after I put in the new coil and cap and rotor.
Sometimes if I mess with the distributor I would get the car to work good for few minutes. Than it goes back to messing up.
Usually it boggs around 20-30mph. If under its good, if over that its good!??!
I am thinking that my ECM is taking a dump, or at least my electronic spark advance.
How can I test my ignition??
I have a volt meter
Old Nov 23, 2005 | 06:39 PM
Dialed_In's Avatar
Sounds like the timing is moving around or you have a loose connection somewhere. Make sure the EST wire is plugged in. Check the connections on the coil.
Old Nov 23, 2005 | 09:01 PM
EST is plugged in, but it might be messing up.
once the car idled high after I put it in park, and I messed with the EST and the idle came back down. However, I mess with distirbutor I get it to work. I mess with timing I get it to work, however it does not keep working good. It usually works for about a minute or so and than back to crap.
My Air fuel ratio jumps from rich to lean to rich to lean. Its crazy.
I am checking every single wire tommorow and I am getting some wires from the junk yard and see if they help.
What elese would you recomend???
ANd it defenetly sounds like an ignition problem to you>???
Old Nov 23, 2005 | 09:02 PM
What do you mean by timing moving around???
With EST unplugged the timing is at 2 advance. Nothing big. I put it on 0 but the car did not sound happy there.
Old Nov 24, 2005 | 11:35 PM
I went out today and checked every wire. Some of them are pressed a bit( coil wire). Other than that, the connections look good.
I am thinking that the ECM is taking a dump, or the fuel pump.
I will replace both very soon.
If you have any suggestions please let me know!
Thanks sooooo much.
Laters.
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
gwade12
Aug 8, 2015 08:17 AM
