Tach inop
Old Dec 2, 2005 | 06:43 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Tach inop
Is there anyway to test a tach. Both of my cars have tachs that dont work. They go crazy when you crank it up and then just read wide open. My 85 Z28 runs off an MSD box and the 86 Iroc is stock.
Old Dec 3, 2005 | 03:35 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Anybody ???
Old Dec 5, 2005 | 10:49 PM
Firebat's Avatar
swap in a tach that is known to be good from a camaro/firebird that has the same number of cylinders. See if it produces the same results.
Old Dec 5, 2005 | 10:52 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Only problem is I can get one that works !!
Old Dec 5, 2005 | 11:10 PM
Firebat's Avatar
I took a resistance measurement across the contacts for +12V and ground, was varying in the megaohms. Measured resistance across where the signal comes in to ground and was infinite, also infinite from signal to +12V. Got the same results for a V6 tach and V8 tach.
Tests were taken with the Tachs disconnected from the gauge panel. I'm having a V8 tach that isn't working, but its completely dead, just took these measurements earlier today even though i'm betting my problem was bad contact where all the gauges connect. So, if you take an ohmmeter and don't get similar results, you may suspect the tach. Still, i would try to find another tach.
Old Dec 6, 2005 | 05:56 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Thanks, that was what I was looking for. Ill check the resistance on mine.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
