inflatable restraint grounding
Old Dec 18, 2005 | 10:17 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
I need to know the proper ground locations for the inflattable restraint wire coming out of c100 bulk head connector. Does it get grounded to the back of the DRIVER'S side cylinder head? ALso, the other blk/wht wire also coming from the c100 connection(pinout label: ENGINE) get spliced with it? My presumption is that it gets spliced with the ac and grounded behind drivers cyl head. Location or wiring diagrams would help. -Thanks
car is origionally a 92 305TBI (RS)
-has ac
Old Dec 19, 2005 | 12:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The ground for it is at the rear of the left hand cylinder head and the wire for it is at pin "F8" of connector C100.
Old Dec 19, 2005 | 12:48 PM
Dirtbik3r's Avatar
Hmm.. So i did have a pretty good guess of where it went. Thanks again Trickter.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
