dual batteries
Old Dec 21, 2005 | 07:03 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
dual batteries
I am going to hook up my laptop with a gps system and a bunch of other power robbing goodies.
I want to run two batteries but I am unsure of how to do it and was wondering if anyone has done something like this.
Old Dec 21, 2005 | 09:38 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I have a dual battery set-up. Second battery is for stereo system and is mounted in the lock box in the rear. There are a few options to do this, I chose using a battery isolator which allows your alternator charge each battery as needed. The set-up is similar to an RV that uses a second battery to run all the hotel services in the vehicle.
Old Dec 21, 2005 | 09:48 PM
jamon8's Avatar
Engine: 350 tpi
cool I never thought of using that area for a battery. what size battery fits back there.
where did you get your isolator and how did you hook up the wiring. this is new to me but I feel I have to do it because I will be going on long road trips in this car
Old Dec 21, 2005 | 10:39 PM
Al Hasse's Avatar
Remove the cardboard lining, and a full size battery will fit there, mine is an Optima yellow top deep cycle. I had a bracket built there to secure the battery in the compartment. The isolator you should be able to pick up at your local auto parts store, should have decent instructions in the package (been too long for me to remember without looking at it).
You can hook up an inverter (also available at auto parts store) to your second battery and then you have an AC outlet to plug in your laptop or whatever.
Good luck.
Old Dec 21, 2005 | 10:44 PM
jamon8's Avatar
Engine: 350 tpi
thanks for the info
grngryoutmyway
Oct 18, 2016 05:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
customblackbird
Oct 1, 2015 04:30 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
