Please help me trace a ground.
Old Dec 24, 2005 | 09:15 AM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Can somebody tell me where my gauge cluster is grounded to? My factory tach used to go crazy when I had it hooked up. Also when I trun on the headlights, extra lights appear on the dash like the turn signal lights and the high beam indicator. I thought this might be a bad ground. Thoughts or ideas anyone? This is on a 1990 Camaro.
Old Dec 24, 2005 | 08:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are three grounding points on your car for the instrument cluster. One behind each cylinder head and one to the dash support frame near the fuse panel.
Old Dec 24, 2005 | 08:51 PM
Engine: LB9, LB9
Thanks man, I think ill check the ones on the heads cause they could be rusted.
Elephantismo
Feb 13, 2019 12:51 AM
gta892000
Sep 16, 2015 12:37 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
justin57
Aug 20, 2015 07:05 PM
