dash, headlight, and turn signal problems, all related
Old Dec 25, 2005 | 03:30 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i've been having a problem thats recently gotten worse. my dash lights will go out all at once, along with the heater and a/c control lights. sometimes i can smack the dash and they come back on. about the same time, i started having problems with my left turn signal, the right seems to be ok. it doesnt always happen, but when i hit it, the left headlight will go dim and stay that way, and the turn signal doesnt come on. on the dash, it will show the turn signal but dim, and not flashing. this can happen whether the dash lights are on or off.
i realize its just a loose wire somewhere, but what wires should i be looking at that could cause these symptoms?
Old Dec 25, 2005 | 11:22 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
theres a dash harness ground wire by the steering column, you will see it right where the steering column starts going into the dash should be on either side of the column
Old Dec 25, 2005 | 06:44 PM
1meanGTA's Avatar
i looked for it but couldnt find it. i found one ground point on a bracket to the left and below the steering column with 3 or 4 grounds together. it seemed solid, and my neck was starting to hurt from leaning on my head down there, so i didnt take it apart.
after my alarm was installed it got worse, before i didnt have the problem with the signals, just my dash lights would go off, but it wasnt as bad and they'd always come back on with a slight tap of the dash. going to check later if one of those grounds is for the alarm and reground it if so.
Old Dec 26, 2005 | 08:07 PM
1meanGTA's Avatar
bump need to get this taken care of, sucks not seeing my lights at night. vader?
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
